2009 280ec, 120 hours on entire boat, leaking into front left corner under V seating dinette. HELP
Sej1969
Member Posts: 31 ✭
It has been stored in outside storage during winter in WA, with the snap on top only/ All the sudden water started accumulating into front of boat under V cushion. Could this be melted ice and snow? Bow is up. We are also thinking it could be hatch leaking or Anchor hatch. Also was some water on upper bed on wall side under mattress, wasn't like that before , that dried out, but we go in after emptying water out completely of V seating compartment from left , an inch or two comes back? it was frozen solid all over we had to pour alot of hot water on cabin door to get open recently. HELP.
the water rusted one bolt on the mirror and lights at bow inside where anchor goes.
First I removed the pads on the both sides of the V-berth inside of the cabin. Next, I removed the white vinyl trim pieces above the mirror, and along the cherrywood cabinet. Then I removed the mirror and the two reading lights.
Next I removed the panels on each side that are behind the lights. They are held on by a screw that is recessed in the fabric.
I had to cut the wires to remove the panels.
I then removed the filler piece on the underside of the shelf.
Next I removed the filler panel in the corner next to the speaker. I also removed the speaker to get to the screws inside the shelf assembly.
I removed these three screws and the shelf came out. The shelf should come out being careful not to scratch the other woodwork.
This is what the cabin looked like with the shelf removed and the front bulkhead disassembled.
My leak was in the area circled in yellow, which was there the nav light and the bow rail were mounted. One of the thru bolts was crooked and the sealant bed was bad.
I rebedded the rail, the thru bolts and the nav light. I used 3m4000uv to prevent yellowing. I placed a generous amount of sealant on the underside as well. This part requires two people, one on the inside of the boat and one on the outside. I also replaced the bent bolt.
