Broken bolt bravo 3 transom water housing
So next issue. Broken 1/4 20 bolt holding water intake housing. Tried today. Heating it with a heat gun and PB blaster was able to grab it with a vice grip but it wouldn't turn. Try the heating and PB blaster if you more times. Anyone have any suggestions? Hesitant to get the map torch in there because the boat is stored indoors with about 100 boats. May have to go that route though. I pulled the oil lube filter and anything else that couldn't take any heat out of the area pulled the steering arm to open up some space. Wish I would have came out. I would have been all set. Going to let it sit with the PB blaster for a couple days as I have to work. I also have a welder maybe weld on a nut but same issue. Or I ordered a right angle drill and some stubby bits. I think I have enough room but that's a whole other issue. I really don't want to go down. Anybody have any other chemicals to try before I try to drill it
we
As Aero3113 said, if it moves, work it back and forth- don't just try to remove it on the first shot unless it moves freely.
And yes I have 2 full sets of anodes to put on yet and paint.
https://jrmarine.com/products/bellhousing.htm
