Solved - Trim Motor Dead - tried all the regular things to make it work and failed
 echandler1971
                    Member Posts: 231 ✭✭✭
echandler1971
VP 5.7 GI-E with DP-SM. Trim just plain stopped. There's no click or anything trimming in either direction. First-off, I have no idea the manufacturer nor can I even see a model number from this 2004 era trim assembly.
I checked the 10amp automotive-style fuse on the left side of that plate - it's good. I even went as far as to replace it just in case. I swapped relays with the other pump to no avail. I hooked a 12vdc power supply to the motor and it made noise so I assume it's good. I popped open the boot connector up top and reseated a couple times.
I know that the green wire makes it go down and blue up, but for the life of me, I have no idea what to check next. It seems like it's an issue between the helm and the unit - likely somewhere at the unit. I doubt the thumb switch would have failed in both directions at the same time; hence my doubts its the switch or for that matter, the 2 relays failing at the same exact time.
I don't see a single breaker button popped at either the battery switch or at the bottom of the helm console.
I'm officially out of ideas.
Dan of Steel
'05 Rinker 360 Fiesta Vee
Post edited by echandler1971 on
https://www.ebay.com/itm/154740270587
Did you check for power at the relays? Swap relays between the pumps to test?
I'm bringing my daughter to the boat to sit at the helm and listen to me yap at her to trim up and down as I check stuff based on this site:
https://www.instructables.com/Troubleshooting-Testing-and-Bypassing-SPDT-Power-/
It's the diagram there that by-far that best explains the system to me. For example, I know I can leave 1 relay in and bridge pins 87 and 30 on the other and I should see it actuate the motor in that direction.
1. swapped relays from port engine trim unit
2. Changed 10amp fuse
3. Tested switch loop to the helm and switch is good in both directions up to the connector boot
4. Tested power in and got power and ground at that point
5. Got 12v to ground bus voltage on various relay pins
Hence thinking ground at the moment. I didn't have the link above till now, so now I can test some more.
