Sterling battery charger same as Pronautic battery charger
I wrote this in a recent post, but not sure if anyone saw it so I figured I would give it a shot on a new post all by itself.
I am planning on replacing both of my battery chargers on my 350 EC this spring. The engine bay is a PD2040 and the thruster/windlass charger under the berth is a PD2020. I read up on many (many) threads on this recommending the Pronautic model for easy replacement. Sticker shock got me a little bit when researching the prices.
Then I happened to come across Sterling ProCharge Ultra. It is the exact same model as the Pronautic (same case, engineering, company, etc.), just a different badging. And (more importantly) it is cheaper! Links are below (one describing the difference between the two and the other for the Sterling website). Has anyone researched or installed the Sterling model? Curious for any feedback.
https://www.sterling-power-usa.com/sterlingpowerprochargeultra12volt40amp-marine-battery-charger.aspx
https://www.youtube.com/watch?v=G5tzBzce94w
Former Boat: 2008 350 EC
Greenwich Bay, Rhode Island
For the bow thruster charger, I use a Guest 10 amp single bank charger. Inexpensive and has been reliable.
https://www.westmarine.com/guest-chargepro-onboard-battery-charger-10a-12v-2-bank-18697359.html?&utm_medium=cpc&utm_source=google&utm_campaign=PMax:%20GSC%3eSmart_Shopping%3eMarine%20Electrical%3eGSS&gclid=EAIaIQobChMIn_DB55-8_gIVcgdMCh1PRgmOEAQYASABEgKw3_D_BwE
So now I have a project coming up some time in the next few weeks. I am going to replace the battery charger in the engine bay and replace all 4 batteries as well. The two house batteries are group 24, going to change them out for 31's. And also replace both starter batteries as they are now 5 years old. Once completed, I will let you know my thoughts on the project.
