Battery Question
glynnalan
Member Posts: 36 ✭
last weekend I beached up running the radio. 5 hours later batteries dead. switched to both...nothing. and the generator would crank over either.
after getting a tow to my slip I plugged into shore power and it fired up both engine + generator.
I have 3 batteries 1 crank and 2 deep cycle.
questions: when I beach up should I flip of AC power to make sure nothings draining? Do both refrigerators run if AC power is on from batteries? Should I replace all 3 batteries? Do all 3 charge when hooked to shore power? Which battery does what? Picture attached; is the back one for the generator and the 2 on the side for house and start?
I actually just added a second battery, switch, and Automatic Charging Relay (ACR) to my 2004 232 BR as described in prior posts on here like MT mentioned. I was terrified that when anchored and stereo with amp are on, and any lights on depending on time of day, that the engine might not start. I installed a Blue Sea Systems 9002e switch and Blue Sea 7610 ACR and will hook up optional start isolation circuit and LED indicator. This might be overkill for my situation but feel better now with the 4th and long weekend. There are some great discussions and diagrams on here about this subject and Blue Sea Systems (and similar products) have great wiring diagrams for your particular situation. I have researched other options but like this system the most. Have a fun and a safe 4th to all would hate to have dead batteries and wreck the fun on these days aboard.
Rob
