Trim pump reservoir milky
johnny44johnny44 Confirm Email, Member Posts: 132 ✭✭✭
I noticed that my trim reservoir on my port engine was low last year. When it was winterized in the yard, the mechanic said that the fitting on the drive was loose (he tightened the fitting and added fluid to the reservoir).
Fast forward to last weekend when I was going through the boat and commissioning the systems after it was splashed for the spring. I raised and lowered the drives - noticed that the port engine reservoir was a little bit low again. Raised and lowered it one more time and noticed that the fluid in the reservoir was milky. Drained the reservoir, added new fluid and tried it again. The fluid is a little milky again.
I'd hate to have to pull the boat out. Can I just keep draining the reservoir and adding new fluid when needed? I really don't need to use the engine trim often (if at all) as I can use the trim tabs as needed.
Former Boat: 2008 350 EC
Greenwich Bay, Rhode Island
  • aero3113aero3113 Member Posts: 9,634 ✭✭✭✭✭
    If it’s not pulling in water now, yes, just drain and keep flushing with clean fluid.
    It might have burped some air and that’s why it went down again.
  • johnny44johnny44 Confirm Email, Member Posts: 132 ✭✭✭
    It's milky, so I am guessing it is pulling in water.
    Yes..water in the system and you have to clear the trim cylinders as well which I'd think hard in the water. I just went through it as one cylinder the seal blew out of do I replaced them and the lines at the cylinders, I had replaced the lines to the transom earlier...
    edited May 2023
    Yes..sounds like for sure...it's going to be hard to clean it all out in the water- you have to purge the cylinders also..I have no clue on the life of that pump pushing water through it....
    Are you in salt or fresh water?
    Salt water. Any issues if I just clean it out as best I can and don’t use the trims for the season?
    Chances are you need new lines to the trim pumps. I don't think not using them will help much, not to mention the boat won't perform well without trimming your drives.
    If it was me, I would do a short haul and replace them. They're not terribly expensive and relatively easy to replace. 5 months is a long time for the salt water to migrate through the system. A new non-OEM pump is $500+.
