Trim pump reservoir milky
johnny44
Confirm Email, Member Posts: 134 ✭✭✭
I noticed that my trim reservoir on my port engine was low last year. When it was winterized in the yard, the mechanic said that the fitting on the drive was loose (he tightened the fitting and added fluid to the reservoir).
Fast forward to last weekend when I was going through the boat and commissioning the systems after it was splashed for the spring. I raised and lowered the drives - noticed that the port engine reservoir was a little bit low again. Raised and lowered it one more time and noticed that the fluid in the reservoir was milky. Drained the reservoir, added new fluid and tried it again. The fluid is a little milky again.
I'd hate to have to pull the boat out. Can I just keep draining the reservoir and adding new fluid when needed? I really don't need to use the engine trim often (if at all) as I can use the trim tabs as needed.
Former Boat: 2008 350 EC
Greenwich Bay, Rhode Island
If it was me, I would do a short haul and replace them. They're not terribly expensive and relatively easy to replace. 5 months is a long time for the salt water to migrate through the system. A new non-OEM pump is $500+.
