Mercruiser Warning Engine Misfire Catalyst Damage
On the way to get gas this morning this Warning popped up: "Engine misfire. Starboard Engine. Reduce engine speed to prevent catalyst damage. Service Engine Soon." Engine sounds fine. Any ideas what causes this and any potential solutions? Hopefully something simple?
The boat is going in on the 17th, so If I can't figure it out by then, I can have my yard take a look.
Mark
2019 MTX20 Extreme
I had spark plugs, rotor, and distributor cap replaced. The yard cleared the code and it did not return. So it was an easy fix.
The mechanic said if the code would have come back it could be the O2 sensors on the catalytic converter (there are two sensors) - but looks like we got lucky.
So just start with the easy stuff first and see if that clears the warning.
BTW, the beeping that the vessel view makes is enough to drive you crazy, there should be a way of muting that after you acknowledge the issue but there isn't.
I was able to fix the misfire issue with starboard engine, but then these two alarm show up which I was not able to fix the communication issue. The engine run perfect, but I can not see any inputs in the vessel view from the starboard engine, but i can see port engine when she is the only one running. a soon i turn starboard engine on the vessel view information disappear for both engine. This issue drive me crazy today.
