Fuel issue
mike312mike312 Member Posts: 6
2004 fv312 took the boat out 3 weeks ago and it used fuel only from port side tank.  Filled it up and yesterday I took the boat out again and now it only used from starboard side only.  All valves are open and have not been touched.  They have been the same since.  Anyone run into this?
thanks
  • Pat310Pat310 Member Posts: 601 ✭✭✭
    You need to shut the cross over valve. Each engine should run off their own tank. The center valve is to isolate a tank if you run into fuel problem in one of the tanks. It should be in off position when normally running
  • mike312mike312 Member Posts: 6
    Thanks will try that out .  Thanks again for your help
  • rasburyrasbury Member Posts: 8,865 ✭✭✭✭✭
    Welcome to the forum @mike312. How long have you had your boat? Any special plans for upgrades? I think you have a couple others on the forum from your area. Lots of good people that will help and you can also search the archives as well.
