Water Heater Plug 270
I just replaced my water heater on my 270. There is a plug on the power wire in the engine compartment that connects to the wire coming from the breaker panel. It has color coded plastic on the inside and 4 square prongs that connect male to female. Some of the plastic is broken inside mine. Does anyone know what this plug is called and where I can get a replacement?
"Mosi on Dahn" 2003 Fiesta Vee 270
... Or does anyone know of a plug I can use in this situation (in engine compartment) that will work as a replacement?
