Gfi
rasbury
Member Posts: 8,780 ✭✭✭✭✭
So...here is my set up: pulled and ordered a new starter and pulled the boat home. I turn the power on and I got zip which is no surprise..another thread...so, no worries I'll put it on the charger. I recall when I pulled the motor and had no batteries in the boat everything would pretty much work on shore power. So hooked it up..turned on the panel at the battery switch. Turned on the shore power, got the light, turned on the battery charger (one battery is in the boat, which I used to close the hatch, no shore power) and got nothing at the helm or cabin lights. The Guage was reading the shore power panel....so for some dumb reason I thought I should trip the gfi. Now nothing works and the gfi does not seem to be clicking it back on? I pulled the panel to do an easy swap on a gfi plug- have to take the whole panel apart to get at it...I have light on my shore power plug. On the 270 it's the only gfi , not one at the head or out by the sink, TV plug in- just the one outlet on the panel. Please just don't say test it for power, you have to explain it to a 5 year old...and is this a "marine" 12v gfi plug? I assume not...
Post edited by rasbury on
