Fixing leak in genny muffler
Spyderweb
                    Member Posts: 947 ✭✭✭
                    At bottom of generator muffler is a screw, that I assume is to drain the muffler for winterization.  Couple of years ago I noticed water leaking from it.  It no longer screwed in tight, so I wrapped it with plumbers tape, it took up the slop and stopped the leak.
Checked this earlier in the week and big leak again with genny running. Now hole is so stripped that tape no longer works. Muffler is a fibrous plastic material. Would it be appropriate to tap larger threads and put the next size screw in to seal the hole?
Alternately, you could try some epoxy on your current bolt. I might attempt that approach first.
There was a lot of water in the muffler when I removed it. Definitely learned a good lesson about winterizing and the importance of running a lot of antifreeze through the genny before winter storage. My guess is that you had some water left in there one winter and it pushed the bolt out.
I've never tapped fiberglass but I'd be careful as it's a little brittle. Go slowly with the tap and back out often to keep the threads clean. Install with a little sealer.
Good luck!
worst case glass/epoxy over the drain hole and always use lots of antifreeze for winterizing.
This is what I do as well.
@Spyderweb I would epoxy the bolt in place and move on. I would sand down the outside surface of the muffler around the hole, cut a small circle of fiberglass mesh maybe 1" in diameter, put the bolt through it, and epoxy it in place. Trying to tap the thin fiberglass seems dicey.
If anyone still wants to take it out, it's easier with the thumb screw than trying to get a slotted screwdriver head on it in the awkward location that it is.
I think I'm good. Thanks for your ideas.
