226 fuel troubles
I have a 2007 Captiva 226 over last winter we developed a fuel leak of some sort. We could smell the fuel as soon as we pulled it out of storage. I left the tank very low over the winter ( less than a gallon). We had a very hard winter in Michigan but the boat was stored indoors. I have checked all of the of the hoses and the exposed engine area with no signs of leaking fuel. I rinsed the bilge with simple green and water. I captured the water and there was about a 1/2 cup of liquid gas in the bilge on the top of the water. We use only non-ethenal fuels in the boat. The only place I have not checked is the tank where it is hidden under the deck. Looking for a little advice of what to do next.
It being so dang cold, and the truth about fittings not being perfect unions, I'd go directly to the basket on the tank.. the five screws that hold the sender and float likely needs tightening after the cold storage.
I went back to the boat this morning and just from overnight there was more fuel accumulated in the bilge. I think the tank has sprung a leak. I see no way that it can come out of it's mounted position without major work. At minimum, removing the motor and cutting at least one stringer. If anyone has performed this operation I would really like to hear about it before I head off to a mechanic.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
You can have the tank pressure tested installed, and can hope for the ability to repair it.. it's a long shot, but maybe... Right? You'll likely need to pull the engine, and remove some fixtures, but I doubt you'll have to cut anything... Though, it may be frustrating enough that you'd want to..
Pulling the engine really isn't that big a deal.. three or so hours and that baby is on land... Pulling fixtures is a pita, I'd reckon, but doable...
Again, sorry to hear of your issues.
BTW, the recommendation from Rinker was to separate the hull and the deck. No need to remove the engine that way but I had a hard time finding a shop that felt that that was a good idea. Most seemed to think that I risked a bunch of stress fractures at best and not being able to get the 2 halves back together at worst.
I doubt it's a systemic problem to all of rinker or all of that model... But you commented about the manufacturing and likely one individual who is in charge of that install... My guess is the person, but, that person represents rinker, too, let's not forget, making it a rinker problem..
Four pin holes in the tank isn't an effect of sloshing about, though sloshing about is the reason why four pin holes leaked so much fuel... Metal fatigues, it's just a fact.. metals that have been processed over and over reach a point where they should be discarded or recycled.. my best guess is the metal used in that tank was stressed before or as it was being made into a tank.. rinker buys tanks, they don't make them.. There isn't a way to know if the tank is stressed before install.. it would look fine, pressure test fine, ultrasound fine.. This makes it an issue leveled at the tank maker.. but, rinker contracted that tank maker and used them, which makes rinker the front door for addressing it...
Man, I'm sure sorry you had to deal with this... It sucks hugely.. do you recall who made the tank? When you go to purchase/replace the rinker, make sure and look at the other models and makes, and avoid that tank maker... Seriously..
Tank failures are not specific to Rinker and every production boat mfg experiences a pretty consistent failure rate in each of hundreds of systems. Glad yours was caught without incident and is now repaired.
Our '04 270 also experienced a tank failure on the previous owners shift and the removal was very similar to yours. Engine/OD removal then one stringer and new tank. I was told that there had been some sort of questionable issue in layup but details were vague if not unreliable. It now has a new 88gal tank and the disillusioned prior owner moved back to his roots in sailboats......as if that's cheaper or problem free (it's definitely not).
Glad it didn't happen on my shift but it's a production boat. Like an RV it's built quickly out of a conglomeration of relatively inexpensive/cheap parts to be sold at the lowest possible price and then shakes/rumbles/pounds along in life when it isn't crusting away sitting idle or neglected for months at a time.
I understand that this isn't a bad light switch or bad door lock design but no boat will ever be problem free. Like Ray said, a single drive failure (God forbid two!) will run $4k-$6,000 alone . Lots of posts fume about whether it was a design issue in every system failure but the bottom line is that these are expensive, complicated toys and every single system has the potential to break, sometimes catastrophically.
Sorry for your issue. Now try to go get some water time. It'll normally do the soul good. If it's not...try sailing. It was good for us for many, many years. Good luck, Mike
RY: most certainly can have diesel tanks leak too. Corrosion, bad welds, cracks, etc. no one is immune.
Knock on wood when you say stuff like that! lol
