Wiring for my 350 with cool fuel
rasbury
Member Posts: 8,738 ✭✭✭✭✭
Someone from another forum provided the following info...I just don't have the electrical knowledge and I don't want to fry anything. Sure the low pressure pump seems to be running, I don't think it's the relay- I have two relays sitting side by side on the top of the motor and not sure which is which...but probing it seems to be the way to go. I have a regular meter and the probe won't fit into the pin area to probe...do you attach something to it to get in there? What do I do for a ground/negative probe? The other pin referenced, where is that at? With where I'm at on this , can I put my volt probes on the plug itself disconnected from the pump, hit the key- if I have voltage then I know everything behind the plug is OK and it get my 600.00 replacement pump?
dang, it's not letting me copy from the other site...I will post.
Which cool fuel do you have (no serial numbe
ECM powers up, hear beep and then applies ground to pin A-19 for couple seconds which powers on FP
If you put meter on pin A-19 or pi 86 of FP relay before key is turned ON you will see 0V. Key ON, 12V to relay coil and "may" see 12V then 0V when ECM energizes relay to power FP relay. When ground is removed will see 12V again
If you don't see 12V at any time then the fuse is blown, MPR is not energizing, bad connection, or relay coil is burned out
Boost pump is powered by the same FP relay. It's a add-on kit supplied by Merc to help stop vapor lock
The Boost pump can be removed and run without for testing with a bypass
