Battery or Charger? or nothing?
ok, over the weekend while we were anchored out for 3 days, I noticed that when I ran my generator and battery charger, the analog meter in the cabin would only jump up to 12.5V at initial turn on. I know it didn't do that in the past, so I became more than curious. I thought maybe one of my two house batteries was causing the problem. So I connected each house battery separately (with and without load) and also read it on digital meter (Dig volt meter) right at the battery. The cabin meter was maybe .2V lower than what I read directly at the DVM. The analog meter on the charger would jump to 40 amps, but real fast go to 30, then down to 20. The DVM I had on the battery would jump from 12.2 to 12.7...then in time climbed to about 13V total. That was, well, maybe ok. But when I'd turn the charger off, it'd drop to 12.3V ish. OK, in time I'd think maybe it would be higher.
I think my charger is not going to that boost stage of 14.4 volts, and also not hitting the 90% charge stage of 13.3V. It is just going to the maintain stage.
Now, after sitting back at my dock for 5 hours or so, the meter was showing 13V (on the analog in the cabin). I didn't mess with removing the load again and checking with the DVM.
Just thought I'd see what others thought. I swear that thing should go right up over 14V initially all the time. how bout you guys? do you see your meter jump over 14V after you apply the battery charger?
Oh, batteries aren't quite two years old, and never taken down below 12V (probably stay over 12.2V). I've always gotten 5 years out of my house batteries.
When you say voltage never went over 11.8, where is that measure? Was that the entire time while the radio was on? After 3 hours did it shut down? What was the voltage when you shut it off after 3 hours?
12.8 is good charge and 13.8 is good with charger on. That all sounds good. Could be your batteries, but hard to tell with the info thus far.
Steve, the fuse for my MB Quart was 70 amps so a 50 amp draw would certainly be a reasonable conclusion. MT
That sounds about right. If you have a significant battery draw whilst charging, it won't be a able to keep up. +1 on AC/DC at the proper volume
Rhetorical question Steve! :-) MT
Wow, that does not make a whole lot of sense! Glad you figured out the issue though!
Good you figured it out. So when you getting a new charger?
