Low? Fuel Pressure 350 mag mpi
I went down the rabbit hole of fuel pressure for a 2008 350 mag mpi engine (1A075xxx). Mercury confirmed I should expect 38 psi at idle and 41-43psi at 1800+ rpm. So I measured mine. Twin engines, both showed 38 psi at idle and only 36 psi at 1800 rpm. I asked Mercury if 41-43 psi is the expected value or just the max value and if there is an acceptable pressure range. They said no, 41-43 is expected and I am low. What's strange to me is why are both engines behaving the same? Just coincidence? Approx. 540 hrs on each. Fuel system components are original as far as I know.
Before I go any further, I wanted to see what your thoughts are? Am I looking at a fuel pressure issue on both engines or am I okay for my serial number and maybe there was a change in software/hardware boosting fuel pressure at a later date?
There is a common issue with paint flaking off and clogging the fuel system on the bravo set ups... diesels don't have this issue which is why diesel hard tops are better!!!!
If it was mine and I'm having no running issues I would assume my gauge and or sensor is a few psi off being both motors are identical.
If it was my boat and I'm hitting the same speeds/rpms that I was when it was 500 hours newer, I would keep an eye on it but it wouldn't be an issue I'd feel the need to address. But, if I was having performance, fuel consumption issues or running/starting issues then I'd dig into it starting with the potential of the paint flake.
It's my experience with an EFI system that isn't getting enough fuel pressure is they'll fall flat on their face when load/rpm is applied, if they even start at all. My experience with EFI is mostly two cylinders engines and they are not nearly as fun
