Big Block in later 232 Captivas
Sometime in the near future I want to repower my 2004 Rinker 232 Captiva. I was wondering if anyone ever installed or even seen a big block (496 or 502) in a later generation 232 with the walk-thru transom. Just by looking at the 5.0 MPI that I have now, I wonder if there is enough room for a big block. As it is I do not think I could put a freshwater small block without interference from the back seat rest.
I know it would be cost effective to just trade in but I like this boat and have already spent untold amounts of money getting it to my liking. I do not mind spending more, it is a hobby and I enjoy working on it, even though there is nothing wrong with it. I already have all of the DTS components to work with whatever engine I repower with.
If a big block won't fit then it is going to be a 6.2.
Not looking for a lot of speed, just maybe 55 or so. Right now it tops out at low to mid 40s
Any thoughts?
it's all about the torque, and a longer stroke- whether you bored or just honed the cylinders and notched the block- it would give a LOT more torque by not only providing more volume displacement, but also a longer power stroke..
fuel delivery has to be addressed with more displacement... everything else can remain relatively the same.. you could expect as much as 75~80 ponies by simply doing that... add in rolling rockers, ported and port-to-gasket matched intake manifold-head-exhaust manifolds, along with some bowl work on the chamber, you can flow as much as 800cc's or so additional flow... it's said that an additional 10cc's flow ~through~ an engine accounts for a pony... that would be 80 more, on top of the 80ish from stroking the engine... 160hp over what, 250~270 now? ruh-roh raggy, you'll be needing brakes on that rig, too.. :-)
you'd be getting that coveted 55mph below red line with that... it would fit without any argument, too..
Robyw1,
I have the 6.2 in the exact year you have. It's a solid 55 mph boat and I've seen 57 at times. Much better economy that going with a 496 I would imagine.
I think Michael T put a big block in his 232. You might message him for details.
