I damaged my prop in shallow water. Is there a specific prop for my boat? I have a 2001 Captiva 232
Are prop specifications assigned to a boat? Can I go to a Rinker Service Counter and tell them the type of boat I have?
Best Answer
aero3113
Member Posts: 9,658 ✭✭✭✭✭
If your boat is out of the water there is a size and pitch number stamped on the prop. If you can reach the prop with the drive up it can be removed while in the water also.
yes. I will have to anchor it in shallow water in order that I can get a closer look. Could not raise the outdrive up high enough to read the number. Thank You.
If it is an Alpha One drive, it is more than likely a 19 pitch prop.
Why not remove the prop and send it out for repair then reinstall??
.....and keep a second one for a spare if you boat in shallow water a lot. MT
