Poopy problem
Good day Rinker forum. Let’s just say I have to replace my poo tank. Where do I even source one?  1995 Rinker 300.
Jake
    i pulled mine out to potentially do the same a few years ago.  You may not find one that is an exact match.  Mine had some decent odors that i was able to track down to a loose fitting and i also installed a Big O filter.  If you start by pulling it, you can get it some good measurements.  There are a bunch of universal tanks out there.  You may need to drill holes for the fittings but the big thing to make sure it fits your location.
  • mattiemattie Member Posts: 1,317 ✭✭✭✭
    I'm number 2 reply........lol
    Be sure to replace sanitary lines.10yr life expectancy before they start to stink too....
  • PickleRickPickleRick Member Posts: 4,133 ✭✭✭✭✭
    Great lakes Skipper has some new old stock, worth a call.
  • GlennyGlenny Member Posts: 28 ✭✭
    Measure yours up and look at the different sizes at any marine supplier did mine 2 years ago. Dimensions were not exact but I got one close to the size  so I could put it back in its spot.
