I have 2008 Captiva 276. I have a small water leak at the stern of the boat directly under the shaft
dbeall1914dbeall1914 Member Posts: 14
edited January 2024 in Engine Discussions
The water is coming in directly under the motor shaft. Any hints about what is actually leaking?
Best Answer
  • Dream_InnDream_Inn Member, Moderator Posts: 7,863 mod
    Answer ✓
    Well, it could be a number of things.   Bellows tend to leak and transom assemblies as well.  The transom is usually around the steering arm.  If you haven’t had bellows changed for a while, I’d look at those first.
