Custom front gauges
Hello Rinker owners!
I am upgrading my GPS units to (two) Garmin UHD2 6XSV on my boat. (second attached picture) I am curious if someone have ever removed the engine gauges and instruments and installed another GPS unit in this place? I know that the Garmin UHD2 9XSV will fit but of course need to see/ make sure that Garmin UHD2 9XSV can support the engine tachs and the rest of the instruments.
Has anyone out there has done this before, I would love to hear your experiences.
Also, if someone has done this, can you buy a blank panel to install in the area where I would remove the old instruments?
Thank you in advance
Patrick Magrum
Canton, GA
Patrick Magrum
Canton, GA
Now for the dash panel. The main issue with the 342 is that the molded plastic guage panel has a curved outside edge. You won't find a blank that is curved. So you will either need to fabricate one or learn to be ok looking at an unfinished edge. I tried using a wrap and it got brittle within a year and started to look pretty bad. That is why i ended up re designing the dash so i could just put in a flat panel. I found plastic panels on Amazon with a wood grain that was similar to the steering wheel and other panels and it looked like a perfect match. A few attempts with a jigsaw and router and i had a handmade dash panel. There are a few things to consider when going this route. Also please don't me discourage you as i am doing the exact same thing right now with my new boat. You need to always start the engines up in the same order otherwise the NMEA system will get confused over port and starboard. 2. All of your guages have to be calibrated to work which is easy on the trim senders and a pain on the fuel. 3. Going from Analog to digital can be flaky at times. I had frustrating gremlins that would pop up every now and then. I would have to remove the sensor from the system and just re do it....finally. Garmin gives you a few templates to use but in the end you will be creating your own so that the read out works for you.
