Hey you machinists: best way to enlarge a 1/2" hole to 1" in stainless steel?
The top plate on my light mast is 3/32" stainless, with a 1/2" cable hole. I need to enlarge the cable hole to 1 inch for some new stuff I'm adding. Any suggestions?
https://www.amazon.com/COMOWARE-Shank-Cobalt-Spiral-Flutes/dp/B0BVTCJBWP
or this?
https://www.amazon.com/Cobalt-Step-Drill-Spiral-Flute/dp/B0BWYC1SV4
I drilled out the hole from 3/8" to 1/2" without too much of a fight using a regular drill bet at low speed, so maybe a reamer will work.
I started by enlarging the hole to 3/4" to see if that will work.
