Baltimore's Key Bridge destroyed by cargo ship allision
LaRea
Member, Moderator Posts: 7,561 mod
Happened overnight, and wow is this ever a disaster. Many deaths. And it will shut down not only a major shipping port, but also a major highway. [EDIT: collision = ship hits a moving object, allision = ship hits a stationary object]
This video shows the allision. The ship was out of the channel and just rammed directly into the bridge support. She had two harbor pilots at the helm.
https://www.youtube.com/watch?v=2kw1hH5XCYU
Post edited by LaRea on
It was heading out of port, 2 pilots were in control. Only 20 minutes into its journey. Mind boggling how this happened. I’m thinking mechanical failure.
https://youtu.be/N39w6aQFKSQ
Sad to hear workers were on the bridge doing patchwork, but luckily very few cars on bridge that late at night. Will be interesting to see what caused the ship's propulsion failure.
The only good that will come from this is improved emergency/abnormal procedures and a more modern bridge design with "dolphins" to avert the next one...and there sadly will be a next one.
This would mean mitigation methods must be put in place ... protect the support. I agree, that bridge came down way too easy. It's unacceptable in my opinion.
I agree with Aqua, except at this point, it was all a straight line out of the channel. Not really a need for a tug. And if there is a need, then there would also be a need either thru the C&D or thru both the bay bridge & bay bridge/tunnel. Which is 200 more miles from Baltimore.
My theory is that once the ship's bow got a little outside the channel, she ran aground, which turned the ship directly into the bridge support. Wiki says she draws 49'. The wall of the channel is almost vertical going from 52' to only 36' at the bridge support.
I come from a world that has focused on mapping so looking at an issue from a map perspective always speaks to me. Here is one that has a nautical map overlay. Myshiptracking is cool in that you can watch things moving in near real time as well as play back the last 3 days. Finally, Vesselfinder gives you a few more options for overlays. All of them are better looked at on a larger screen so I would advise not using your phone to hit the links. They all integrate with AIS data as the source.
