Can I pick your collective brains for an engine start problem? '94 Rinker 265, mercruiser 5.7
Hi,
Our boat is on the Thames in London and been in a marina all winter. Now having trouble starting her, wondered if you had any advice before I call an engineer.....here goes....
Tried to start engine and just got a single 'click' with a drop in voltage at the helm
Have checked batteries and they both read 12.4v so look ok
Checked continuity across the breaker that sits above the engine, next to the slave solenoid and that looks ok
Ran a wire across the two heavy duty points on the solenoid (to effectively bypass it) and get a 'click-click-click' when turning power on.
Is it time to hit the starter with a hammer? Or is there some further testing I can do?
Thanks in advance
AJ
Thanks in advance
AJ
Is there a way of checking the batteries effectiveness under load?
I got a Romondes BT200 tester on the batteries and the results show as per the amp meter, ie 12.3-12.4v. Also did an MCA test (every day's a school day) and it reads 629a and 630a across the two batteries so I figure enough power combined to crank.
Next I have taken the emergency power off switch out of the boat to give it a good clean (in previous years I've had to give it a thump occasional to close properly).
If that doesn't work (and I'm not optimistic) I think I'll call in a pro!
BTW, I haven't tried to crank it by hand.....it's a tight fit down there and a few too many beers have taken their toll!
I did manage to squeeze into the engine bay and turn the engine about a quarter turn with a box spanner, so presume it's not seized. I also managed to get out!
So, bypassed the isolator switch and tried to start the engine and got a horrible grinding noise from starter, I assumed it just wasn't quite engaged so gave it a thump with a rubber mallet. I then got what I consider a 'normal' flat/low power battery click accompanied by V drop of at helm and then back again.
I then re-checked batteries with tester and now getting 'REPLACE' reading!
So, new isolator switch ordered. Both batteries back home for a 'repair' re-charge and will test again before buying new ones.
