Exterior drive oil hose replacement
aero3113
Member Posts: 9,623 ✭✭✭✭✭
I didn’t want to hijack Joe’s post but I just verified I kinda have the same issue except I believe it’s the hose that’s leaking. Yesterday I noticed oil dripping from the side of the drive. I lifted the drive and looked around, I’m pretty sure it’s coming from the hose and is only leaking with the drive down. The bell housing has to be removed to gain access correct? Should I replace the transom fitting while I’m in there? I do have one on order just in case I break it when removing the line. Any tips would be appreciated!
https://youtu.be/yTTXvJK9tq0?si=9UDQInIsBGNFEe3m
The hose could probably be done without removing the drive, but the transom fitting... yikes.
