Seawater strainer
jaubry
Member Posts: 125 ✭✭
Does anyone know the size of the strainer basket on the Sherwood pump for the Koehler generator? I have a 330 EC
jaubry
Hey J, I don't know the length or width of the strainer, but this might help: Sherwood at www.sherwoodpumps.com or Pentair Water 1-800-471-0460 or 1-651-766-6300 The Sherwood Pump Model for the Kohler 5000 watt should be: the 18005-SHW .... 1" strainer 20SS BUNA Clear Bowl .....bar code 7 34943 08488 8 Hope this may help. MT
Thank MT. Great info
I accidentally dropped the gasket in the water while cleaning the bowl. Could not find one anywhere, it's like a. 3" thick rubber oring/gasket.
I ended up finding a 3" rubber ring/gasket for an RV black water hose that fit perfectly.
It seemed that all I could find was the small 1" strainer parts, nothing for the 3". No numbers were on the strainer either, I thought I had a number but ended up being the fax number to Sherwood.
