Vacuflush not pumping
aero3113aero3113 Member Posts: 9,466 ✭✭✭✭✭
The head stopped building vacuum. Green light is on but nothing happens when the foot pedal is pushed, just water flow vacuum pump doesn’t come on. What should I look at first? I tried a plunger so I don’t think there’s a clog.
Post edited by aero3113 on
  • YYZRCYYZRC Member Posts: 5,348 ✭✭✭✭✭
    edited June 2024
    I had issues with my vacuflush on Friday. I replaced duckbills and bellows last summer so I was pretty confident that wasn’t the issue. It was a clog at the elbow where the poop enters the vacuflush “tank”.
  • aero3113aero3113 Member Posts: 9,466 ✭✭✭✭✭
    Yea, nothing was flushed other than liquid and some toilet paper. I’m thinking the vacuum switch went bad. I think there’s a way to test it. But if the green light is on, that means it’s holding vacuum, correct? It’s possible there is a clog.
  • Aqua_AuraAqua_Aura Member Posts: 2,681 ✭✭✭✭✭
    edited June 2024
    My vacuum switch went bad and I ordered a new one, in my case that system was staying on and not building vacuum because the diaphragm switch had a bad seal. You can push on the switch portion of the diaphragm vacuum sensor to manually turn on the pump and then I would check for power at the pump with a test light and manually press the diaphragm switch.
    Post edited by Aqua_Aura on
    Thanks @Aqua_Aura , I’ll try that.
    @YYZRC the only way to access is through the galley fridge, correct? The port side seat storage bin should be removable!
    If the diaphragm failed it would leave the pump on however if the switch portion failed it wouldn't turn the pump on. It's a really simple system even an aircraft mechanic could figure it out 😉
    Those diaphragm switches are surprisingly expensive.
    @Aqua_Aura if the switch portion failed, would I still have a green light in the head showing good vacuum? Since I have the green light, why won’t it flush when I push the pedal? Would a bad switch cause that?
    Not sure what the light indicates. I don't have that. If the light is indicating "ready" as in it has vacuum than maybe your switch is stuck in the off position and that would explain why the pump is off and the light is green thinking it's ready.
    Yes, the green light indicates “ready”. When the pump is running the red light is on and indicates “do not use”. So it sounds like it could possibly be the switch. I read that you can jump the B terminals to test the switch.
    Sadly yes, icemaker or fridge has to go.
    I don't see why not. You would just be bypassing the switch and supplying voltage to the motor outside of the switch.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,793 mod
    I'm betting you have a clog.  I have the light and what sounds like the same setup.  Extremely familiar with it (FYI, if you need parts, or even an entire new unit, I have all of it to sell).  Usually if switch is bad, it will keep running as it only closes when vacuum pulls it enough to break the connection.  This wouldn't have anything to do with duck bills, again if they were bad it would keep running.  Green light usually means it is vacuumed and ready to go.  Clogs usually happen right in bottom of tank.  When you flush, does the water just stay in toilet?  If yes, turn water off, run it out in sink.  Then hold ball open and, using rubber gloves, reach into toilet and see if there is anything in the hole in the bottom.  (this happens sometimes on my boat after a make good use of it :- )
    I did some troubleshooting and jumped the switch at the B terminals and the pump came on. I then went to the toilet and tried to flush and it worked as normal but the pump did not come back on to vacuum up the system. I replaced the switch and all is good! ⚓️
  • earl1z19earl1z19 Member Posts: 356 ✭✭✭
    That switch is stupid expensive for what it is but better than **** in a bucket I suppose
    Yes, cost me $162 including tax! Cheapest I could find and it was a local shop so I was able to pick it up.
    Pretty much the most expensive part in the VacuFlush system.
    Hate those things.
    I've got a couple of them that I'd sell for much cheaper if anyone needs one. I'd sell one, but the other is on a completely rebuilt "spare" box ready to go.
