Water Flow Problem
Pat310Pat310 Member Posts: 579 ✭✭✭
Had an overheat issue this past weekend. 2003 310FV with 5.0MPI’s. As soon as i throttled up outside the no wake zone the starboard engine alarm went off. Shut down immediately. Engine cooled down below 170 and started back up. Went down to 150 right away. Throttled up again and temp began to climb so shut down and headed in on port only. Today went to boat and same result. Water pressure on starboard fluctuating 3-6 psi at 1000 rpm temp 151. Pressure drops to less than 1psi at 2000 rpm and temp starts climbing. Idle back down, psi back up temp back to150. Any thoughts?
