Kohler EC62 Low Seawater Pump Pressure
I have a Kohler 7.3 genset that shut down over the weekend with a EC62 code. The exhaust water flow is probably 10% of what it normally is. It will start and run for about 10 seconds then shut down and get the same error code. These are the things I've tried and still get the same result:
The strainer had a small amount of debris - cleaned it and no better.
The impeller seemed to be the next obvious fix so I replaced it. The one that I removed have a couple of small cracks but no missing pieces.
I checked water flow on the output side of the pump and it seems reasonable but I don't have any real experience to know if it is correct.
Also checked water flow on the output side of the heat exchanger and it also seemed reasonable.
Used a brush to clean the seacock intake and blew air through the seacock from inside the boat.
I used a garden hose to supply water from the hose that attaches to the seacock. It ran fine for about a minute and then I shut it down with no error code. Reattached the seacock hose and still get the same error code and small amount of water flow out the exhaust.
What else should I check? Thanks in advance!
Ray
2006 390
Previous 2000 340
Could the water pressure switch reduce the amount of water coming out the exhaust?
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
Yes, definitely a possibility and easy to check.
Ray
2006 390
Previous 2000 340
