Cruisair AC won't heat -- stuck reverse-cycle valve?
LaRea
Member, Moderator Posts: 7,934 mod
Another topic for a cold Michigan day. I have two Cruisair air conditioners that blow cold air when set for reverse-cycle heating. That generally means the refrigerant reversing valve is stuck. I've done the usual things:
* Verify that it's programmed to allow heating
* Verify that the valve solenoid is working (checked the magnetic field -- same as a "known good" unit)
* Smack the valve a few times with various devices
Nothing has worked. Are there any secret tricks I'm missing?
I run off of a 3800 watt genny, I've noticed the ac runs perfectly but on heat will kick the breaker after the first cycle so verify sufficient output voltage.
I've never had the boat out in freezing temperatures.
Those roll around units are handy if you have the space
