342 mid bilge cleaning
John41
Member Posts: 118 ✭✭
How does everyone clean their mid bilge? I took a picture and I see a lot of black. It’s hard to clean it through that small access under the aft bed.
I would use a toilet brush and the best bilge cleaner you can find. You’ll probably need to extend the handle on the brush. Hose, scrub and vacuum it out a few times. Then for the final step, spray it down with some Mold Armor brush it in (use a clean brush) let it sit for a half hour then rinse/vacuum out.
@PickleRick, I read your post, laughed, then sure enough, here it comes…
Walmart, dollar general, family dollar, dollar tree...etc
I spray on, scrub in. Wash off before it dries. Repeat if necessary.
Will also work on monkey fur headliner although try in small spot to verify bleaching won't occur.
@aero3113 probably has that bilge on his checklist! His cleaning and maintenance is beyond excellent. Pretty sure him and @LaRea have a contest to see who keeps the most waxed surfaces on their boats.
