Battery issue
Pat310
Member Posts: 598 ✭✭✭
While heading out for a nice fall boat ride, about 20 minutes in, I started losing voltage on both start batteries. Quick U turn and hit the throttles. Voltage at about 10.7 by the time I hit the no wake zone. Alarms blaring. By the time I get tied up, down to about 9 volts. House battery stayed at 13 volts. Plug in shore power, tuned on battery charger but voltage kept dropping. Had a commitment and shut off batteries and shore power before leaving. Any ideas? I’m thinking maybe battery isolator that it affected both start batteries. It is the original from 2003
Two of them? I'd think more the isolator. Curious if charger got them back up and fully charged.
When the battery is heavily discharged it'll take up any spare amps available, and when the alternator reaches a point where it can deliver enough amps (at higher RPMs, leaving the no-wake zone), the batteries will suck up all that is available, which can exceed the 60 amp breaker capacity.
The solution is to charge the batteries with a smart charger first, assuming that they aren't damaged, but I'd definitely be suspect of them if they got that dead. A flooded lead-acid battery can be severely damaged if discharged below 10.5 volts.
