Boat Blocking and Stands
kordokordo Member Posts: 245 ✭✭
I have been storing my 360 indoors for the past few years.  The marina has usually put the boat on 3 keel blocks with 6 stands.  This year they used two Brownell stands as pictured.  Doesn't look as stable as in the past to me and any issues with the bottom buckling?  Any expert opinions?  Thanks.
  • TonyG13TonyG13 Member Posts: 1,365 ✭✭✭✭
    Can't address the blocking question, but is that your tender between the boats?
    What drives me crazy is that a yard charges per square foot for storage then puts someone else's bow over my swim platform, or like here, throws a PWC or some other storage in a space I'm paying for. End of rant.
  • YYZRCYYZRC Member Posts: 5,327 ✭✭✭✭✭
    Those are some awesome casters! Gotta be the better part of 10,000lbs on the rear cart.
  • kordokordo Member Posts: 245 ✭✭
    Tony, that's not my tender between the boats and yes, I hate it when someone else's bow is covering my swim platform.  One time, I could not get my engine hatch all the way open to disconnect my batteries and drain my engines.  It was a tight squeeze.
    YYZRC, the rear Brownell is rated at 10,000 lbs, which has me a little worried.  The boat with all my crap on it is about 16,000 lbs.  I'm guessing/hoping the forward Brownell is supporting 6,000 lbs.
    I think the spec for the 350 was 15500lbs dry. Add the hardtop and some fuel and gear and yes I agree 16000 easy.
    If it was me, I would tilt the drives up just enough so that if the casters did collapse, the skegs wouldn’t hit the ground.
