seals
mbnarneymbnarney Member Posts: 170 ✭✭
I noticed that there is drive fluid dripping where the rear cover mates to the upper unit. I can not tell if its coming from the top cap or the rear cover. My thoughts are to drain the fluid and replace the top cap O-ring and the rear cover seal. I looked at the manual on line and it calls for a special 3m sealant. Is this a pretty straight forward job or is there something lurking there I need to be aware of?  I cant seem to find this 3m sealant so I am thinking of using "Perfect Seal". Does this just go on the seal itself or should I use it on the surface around the seal?
