Toilet Issue
EasybeeEasybee Member Posts: 22
Model: 2005 Rinker Fiesta Vee has a Jabsco quiet-flush electric toilet, model 37245-series mounted. The issue is the rinse water supply features is not working very well when flushing. The PAR-Max 4 pump was replaced. The toilet will dispose the body waste, however, rinsing the bowl no water down pour. Can anyone provide a resolution to fix this? Or do the bowl needs to be replace?
  • TonyG13TonyG13 Member Posts: 1,384 ✭✭✭✭
    @Easybee - Folks on this forum love providing help to others, but I can't help noticing that over the last couple of weeks you've asked for help on your windless and engine issues - and people responded with  long, well though out answers, and with questions to you asking for more information and you haven't responded to those.
    Could you please take a look at those posts and respond to the people who are trying to help you. It would be appreciated.
  • raybo3raybo3 Administrator Posts: 5,568 admin
    What Rinker do you own? On my 342 there is a filter strainer in the aftcabin under cushion on the port side near the A/C strainer. Check to make sure its clean. You may have to prime it also.
    Agree with Raybo, is the thru hull leading to the toilet raw water inlet open?
