how to charge 2 batteries in a captiva 192
rkinrossrkinross Member Posts: 178 ✭✭
My boat mechenic told me I did not have to remove the batteries and keep them on a charger as I have always done in the past.  When I go to raise the stern drive to keep it higher the batteries do not seem strong enough to raise it.  I have a battery charger that worked for the past two years on these batteries.  The boat has a selection switch to select the batteries or a setting for both.    Do I have to charge each battery one at a time or is there a way to charge both batteries at once if the selection switch is set to both.  I was thinking on placing the positive clamp from the charger on battery one and the negative clamp on battery 2.
