Engine
newbienewbie Member Posts: 2
Still looking at a 310FV that has Merc5.0 and wondering is it fresh water cooled and how would I  know. Trying to get educated. The boat is a 2002. Thanks
  • aero3113aero3113 Member Posts: 9,580 ✭✭✭✭✭
    edited June 4
    Take a look at this link. If it’s fresh water cooled it will have a heat exchanger on the front of the engine (big cylinder on top front)
    https://www.dougrussell.com/mercruiser-383-mpi-bravo-fresh-water-cooling-350hp-2.html
  • Dream_InnDream_Inn Member, Moderator Posts: 7,817 mod
    I used to own a 2002 310 with 5.0 Mercs.  Loved that boat!  Probably the only complaint I had was how difficult it was to change the impeller on the generator.  I had it for 6 years and did all the maintenance myself.  Ask any questions you want.  That model does have Smartcraft, which is very nice if you want to connect up and use it.  Everything is very easy access and not bad to work on (except changing out the water heater).
