Mice
TonyG13TonyG13 Member Posts: 1,413 ✭✭✭✭
Got to the boat this morning after winter haitus. Had not been out to see it since November. It's indoor, heated. Started getting set up to do some putz work and just felt something wasn't right. Looked around and lo-and-behold -- the four or five granola bars that were in a bowl in the galley where gone and the wrappers were spread like confetti all over the counter. I then started noticing mouse droppings.
At this point I started a methodical teardown of every single compartment and opening looking for any more signs of life. Found some paper towels shredded up under the galley sink, then two mini nests made from some paper and cotton towels in the storage under the couch - and then hit what I believe to be the main nest, motherlode, in the storage area under the mid-ship berth. Looks like they set up shop inside the plastic bag containing an extra canvas connector using the munched paper towels. The bottom of the bag had a hole which I think is how they came and went.
I vacuumed, Clorox wiped, and then bagged any and all surfaces I though they came into contact with and trashed it all. Here's a few pics. So far, couldn't find any signs of any chewed wires or tubes - just towels.
Now I'm just wondering if they were/are still aboard this morning when I got there and went deeper into hiding - and what will they do when they come out and find their home gone? Will they jump ship onto another boat? Or just set up again? I plan on going out tomorrow with some traps -- and I sent the yard owner an email letting her know. Because when I was getting off my boat, I saw this on the wall of the boat next to mine...
So he's probably got them also.
Anything else I should do?
  • aero3113aero3113 Member Posts: 9,658 ✭✭✭✭✭
    @TonyG13 , how are they getting up and into the boat? Hopefully they’re out now but try to prevent them from getting back in.
  • TonyG13TonyG13 Member Posts: 1,413 ✭✭✭✭
    That's a good question. The swim platform is backed up to, but about 6" way from, a horizontal support beam which is at about the same height. My power cord is draped along that to the outlet box. I'm guessing they are traveling along that beam from boat to boat and then either hopping on/off or using the power cord?. That's what the drill and charger are sitting on in my neighbor's spot (in the last pic) - where they also stopped for a snack.
    I'll probably set the traps for the weekend and see what happens - and then load up the boat with dryer sheets, pepermint oil, and maybe lavender moth balls.
    Any other home remedies to reccomend?
  • LaReaLaRea Member, Moderator Posts: 8,001 mod
    Those #^@*$^ emm effers can swim.  I chased one away at a marina in Lake Erie.  Every time it surfaced, it would look up and see me, then dive and keep swimming.  Since yours has learned a path onto your boat, trap and kill is probably the only solution.  Sorry to hear it!
    Definitely will not be giving quarter to any interlopers found aboard.
    I am freaking out a bit after reading about the potential dangers of mice turds. I guess they carry a fair amount of diseases which can get transmitted via airborne (droppings) or touch (urine) and you're not supposed to vacuum up droppings -- which is what I did.
    I did wear gloves and did have a HEPA bag on the shop-vac, but I did not wear a mask.
    Cleaning the hard surfaces is easy, but soft surfaces like the carpeting and cushions will take some thinking. And all the towels and linens they rummaged around will now either get dumped or put into the wash in the high heat disinfect mode.
  • captkevincaptkevin Member Posts: 486 ✭✭✭
    I hate the little buggers
  • IanIan Member Posts: 3,020 ✭✭✭✭
    The granola bars possible attracted them.
  • PickleRickPickleRick Member Posts: 4,289 ✭✭✭✭✭
    X2 getting rid of all food on board.
    Put out some traps.
    Hope you can get rid of your new unwanted crew before they do any more damage
  • Rich_Rich_ Member Posts: 295 ✭✭✭
    Definitely trap them, the old time spring traps on a wood board. Do not put out poison, when they die in a hidden spot, it will stink.
    I also prefer the spring traps, even the newer plastic ones.  While I absolutely hate mice I don't think the sticky ones a very humane
    Went back to the boat this morning. No signs of any activity overnight. I set up spring traps in the various areas I found previous activity. Taking no prisoners.
    I'm guessing this was their path to get aboard...
    I agree it was probably the food, but in 25+ years of indoor storage this is a first for me. I always have had a couple of power bars to snack on while working on the boat. Lesson learned.
    I did go into the yard office and told the owner. She reacted immediately by calling in her guys to pull all the yard bait stations and traps to check them and refill them. And to also remind them that they also should only be eating in the breakroom and not on the storage floor.
    I'll check my traps next week and see if I get anything.
  • Lake_BumLake_Bum Member Posts: 1,120 ✭✭✭✭
    Bounty dryer sheets is what I've used for years and years in my RV's, no Mice yet.  When I am anchored at the beach, if there are signs of Mice, I will use plastic plates, cut a slit, and slide it over my ropes.  It blocks them access from climbing up those ropes....
  • WillhoundWillhound Member Posts: 4,237 ✭✭✭✭✭
    Absolutely that's how they (it) got in. Easy for any mouse. I've seen them climb a concrete wall if not completely smooth. Can also jump astoundingly high for their size. Over many years of boats both large and small and now travel trailers we've learned that food in any form is a no-no. We even remove all spices. Missed a takeout ketchup packet one year.....mess in the spring. Also, any paper towel, toilet paper etc. Even with no food they love it as a nesting material. As noted, poison is a no go, never sure where they're going to hide and die. Spring traps work well, as long as you can check and clean it regularly. I'd also screw a piece of wire to it and attach it somewhere because I've seen them drag a trap a fair piece if it doesn't immediately kill them. My go to is a pail trap as shown. Use plumbing antifreeze since it won't freeze and the alcohol sort of preserves them so no smell.
    Simple and effective....but it looks like something Tom would put out to catch Jerry!!! Lol
    Thats awesome
    A friend of mine makes mousetraps with a 3d printer.  It's a modified bucket, with a trap door on the top.  One night he setup a security camera, and caught EIGHTEEN Mice!!!!   Total ICK feeling, knowing there were that many in his garage!!!!!  Hahaha
  • YYZRCYYZRC Member Posts: 5,367 ✭✭✭✭✭
    @Willhound will a regular Gatorade bottle work? I don’t like the zero sugar  ;)
    Yep! As will a beer can, water bottle or what have you..😆
    edited February 14
    @Willhound - I hope you don't mind but I cross-posted your photo to the Great Loop forum.  It's a clever solution, especially filling with antifreeze.
    No worries @LaRea . Certainly not my original idea. My buddies have been using them in hunt camps in Northern Ontario for decades. They usually use the old oil from their generators since it's handy and also won't freeze. Does stink a bit though which gave me the idea of the plumbing antifreeze.
    Regular water works fine too.  They'll drown
    edited February 17
    Yeah....where you live. Try that here in winter and you'll find the little beggars playing ice hockey....😆
    And, trust me, you don't want to see or smell the results with just water if you can't regularly visit to dump it out....🤮
    Post edited by Willhound on
    I guess I didn't even think of the FROZEN part of using regular water haha.  My garage is heated, so I'm not worried about the anti-freeze aspect.  But I completely get it now!
    Just got back from inspecting the traps. None tripped - and no signs of any new activity.
    So my guess is we just served as an Airbnb for awhile until the food ran out and they moved on to more fertile grounds.
    I did put a few more traps out and a lot of Bounce and Uncle Gus's mouse repellent just about everywhere.
    So the boat should smell like combo peppermint and Bounce when I go back. And hopefully I remember where I put everything before we launch in the spring!
    Glad to hear that you haven’t seen any more activity. Getting mice is one of my biggest fears, with the boat and now the camper. A friend of mine forgot a ketchup packet and they found it. I used to roll up dryer sheets and put them in all of the thru hull fittings. Fortunately never got any. Haven’t seen any in the camper as of the last time I was in it. Fingers crossed that it is clean when I open it up in a month or so.
