marine engines running rich
I have noticed it seems marine engines run very rich. You can normally smell them running at idle and underway. This is even with fuel injected engines. Why is this? Also is there a way to flash the ecm for better performance? Mine is a 99 5.0 tbi. I would think the newer ones have more advanced ecm design over the older ones. I would think that making them run so rich used more fuel and is not as good on ring seal?? I have noticed this on several marine engines not just mine. I had two Honda pwcs that where port injected and they would make them selves black on the transom area because they ran so rich.
Now the newer ones that have o2 sensors, they can safely advance timing and trim fuel. You'll see improvement with those... The controls on engines in marine environments has been limited until the advent of pcm controls and being able to reconcile trim and spark with knock sensors and o2 sensors to sniff exhaust... Erroring on the side of caution (rich) is mucho better than risking lean.
I'm sure you could flash the ECM..but a boat motor runs far different than any car/truck engine. I would avoid it and I doubt you would get much performance change out of it anyways.
you can dial back your fuel pressure as the easiest way to reduce delivery. we're just talking a nudge, now... this is a scary prospect to me, though.
you can advance your timing from the 8~10* OE request to around 20*, and just fuddle around until the engine is full temp before hammering on her.. you may even get by with 30ish degrees.. this will allow more time for combustion and burn the excess, or what's being NOT burned right now...
I would do one or the other, not both.
you could also advance the timing at the crank for a mechanical advance by aligning a few teeth off of dots, but, I'd rec you not do that and just use the light, instead.
on a PCM controlled engine, the only way you can advance the timing is either with a programmer/flash or by doing it at the crank... you can also, though I don't rec it, index your ckps to do it... Does your TBI engine have a PCM? Some of the early models didn't. If it does, you could address your fuel delivery there with precision, which makes altering fuel trim a less scary prospect and something I wouldn't hesitate to do...
reducing fuel delivery will do nothing but save you some fuel, though- and will actually reduce torque for the same RPM's as you're seeing now... adjusting the timing, however, will absolutely power your ride up- maybe as much as ten ponies over stock at any given engine speed... with the low compression, and the low operating temperature of the engine, I'm willing to wager breaking something is not likely to happen... I further wager that Merc, along with every other marine manufacturer, lighten the spark timing simply for added engine longevity from catastrophic failure, and that alone.
on my wee lil 4.3 with the thunderbolt ignition, base timing is set by connecting two wires- one from the dizzy, the other in a harness that lays on the intake manifold... wham bam... base timing... you just have to kill the engine and cycle the key to remove it from base timing..
I don't know how it works on a TBI engine. What kind of ignition controls do you have? is is PCM/ECM controlled or a thunderbolt? Do you have mechanical fuel pump or an electric fuel pump?
