loud pop on increase acceleration
Hi guys. My son and I were driving about 3000 rpms and when he went to accelerate a little we heard this loud pop. We both looked at each other and thought maybe something in the engine area fell (hopefully) (we have a plastic carrier screwed to the floor in there to throw minutia) The temp didn't seem to increase the rest of our ride (maybe a little higher then I thought normal at 163is. I usually notice it hangs right at 160. Upon returning I noticed it rise a little to 170 when I came off plane fast but it returned immediately (so impeller okay from reading). My exhaust manifold was hotter to the touch then normal. As I have been taught to see if I can hold my hand on them and this time I could not on the starboard side. Any thoughts? When the exhaust manifold clogs does it make a noise? Thanks
You may have one cylinder or bank of cylinders running very lean, and the other side attmepting to compensate by running super rich.. leaving the black stuff, and leading you to trim fuel out of an engine that is already lean on one bank/cylinder.. you don't wanna know what happens when you do that.
So.. pull your plugs and compare the business end of them against a chart... It'll tell you rich, lean, predetonation from too advanced timing or or retarded.. check your fuel rail pressure.. momentary loss of fuel pressure during acceleration can drop pressure until it catches up, and lean causes backfiring..
Lean is hotter than rich.. a lean bank, which is why one riser is hotter, can be obstruction in the fuel supply lines going to that bank, a vacuum leak on that sides runner, or something similar.
Pull all the water lines off the motor and you MUST find all the pieces of the impeller. Put them back together like a puzzle.
