Rinker 280 EC accessory switches
jbounce3jbounce3 Member Posts: 15 ✭✭
I am trying to connect a pump for a misting system.  It seems as if the accessory switch would be the correct location.  However, I can't determine what load is connected to the two switches on the helm.  Can you help me?
    Pop the breakers until you lose power to that switch. That will give you an idea of power rating.
  • pepmysterpepmyster Member Posts: 308 ✭✭✭
    My accessory switch controls the power for my gps. That's all mine does.
    The acc switch for the optional washdown pump is located next to the wiper switch. It is prewired back to the engine compartment and the wires should be coiled up on the wiring harness between the batteries and the hot water tank. The wire colors are red w/brown tracer and a black wire on a mate-n-lock connecter. It should have a 15A breaker. The breaker is labeled Acc/washdown pump.
    The rocker switch, right ?
    Here is where the washdown pump Acc switch is on the 'new' 280.
