A/C drain
Looking at the A/C unit will winterizing I notice that the pan under the unit was rusting and there was no drain pipe attached to the pan. There is actually rubber grommets attached to the pan marked drain but nothing attached to any of them. Should it have a pipe attached to it or it just overflow the pan when full.
300 Express 2007
Thanks
300 Express 2007
Thanks
CONDENSATOR : MERMAID CONDENSATOR
The Mermaid Condensator is the solution to water in your bilge! For anyone looking to preventcondensation from reaching the bilge or the sump pumps, Mermaid has your solution!
Working the the "Venturi" principle, the Mermaid Condensator is installed in-line with the marine air conditioners water discharge line. As the marine air conditioner and sea water pump are running, the device creates a vacuum effect and literally pulls the condensation water out of the drain pan, merges it with the discharge water, and you condensation is now overboard! The principle here is to leave your boat a "dry boat" by removing all condensation from the marine air conditioners drain pan, bilge, and/or sump pump.
That mermaid device would work well: IF....IF...IF you can keep it clean. Scum, dust, dirt etc mess these things up.
http://www.dometic.com/enus/Americas/USA/Marine/
