Rinker 246CC performance? Expected a higher top speed?
I was wondering why my new 2013 Rinker 246CC with a 350 MAG Brovo 3 set up wasn't performing as well as I expected. I am only getting a top speed of just over 40mph (GPS) when most of the reviews show this boat with the same engine package getting closer to 50mph. Is anyone else have having a similar experience? Any suggestions?
Besides the low top speed, the boat runs great, it does get up on plane quick also.
The engine states that at WOT, the RPM range should be between 4800-5200rpm. I am seeing about 5400rpm at WOT. This would be with a "normal to light" weight/fuel load. With a heavy load, WOT rpm is a little lower ~5200rpm.
The boat came from the factory with a 4 blade forward prop/ 3 blade rear prop set up, 24 Pitch (close to 14" diameter as best I can measure). Could it be that I would benefit from an increased prop pitch, say a 26P?
Any idea how much top end speed I would gain and how much my WOT rpm would drop? New Bravo prop sets are like $1500, I don't want to go out and by a set just as an experiment. Doe sanyone have any suggestions? Thanks!
Eric from Michigan
Eric from Michigan
x
To follow up on Michaels questions: I waited until I had about 40 hrs on the motor before I started my tests (have 50 hrs now with same results). Weather conditions have not been extreme, 70's, not very humid. I do not have trim tabs on the boat, I have tried everything with the drive trim. It seems to trim normal, it is fastest with the trim up pretty high at WOT.
I'm not really one to care that much about overall speed, but as Michael mentioned, I spent a lot of money and don't want to feel ripped off.
Mine has 22.5p props and bravo 3 2.20 ratio.
I assume you got it from hideaway? If so I'd def check with them, because that's close to 10mph slow. Maybe the engine isn't making the power it's supposed to? I dont use trim tabs for too speed runs at all.
I'd bet the factory installs the props, as all the new ones I see on the trucks have props installed. Last resort look at hill marine, they have bravo 3 4x4 props that are supposedly really nice
x
Wow.. you guys are making me feel pretty good about my boat!
2014 260EC 350MAG/Bravo3. WOT (only once so far, for 20 seconds at most) saw 45mph on the speedo at just under 5100RPM and still slowly climbing (very slowly)! Just me (300lbs though), full cooler and fridge, very little water and just over 1/3 tank of fuel. High 60's temp, low humidity in ~60 degree water (Lake St. Clair), no bottom paint, cleanish hull (less than 1 month in a well).
If I knew what props were on my boat, we could compare. My guess is that you have "cruiser" props on your boat (sized/pitched like mine). That would explain the "less than expected speeds", with "too high" RPMs (same props as my boat, but less weight and wetted hull). Plus, I believe (someone can confirm) that max HP is right around 5000RPM-5100RPM, and as you go above that power decreases.
Any other 246's know what props they have out there???
EDIT: All of that being said.. if you loaded down your boat, full fuel, lots of people, food, toys, etc., 90 degree temps, etc., those props would probably be really good.
I am by no means an expert so don't put too much stock in my comments, this is just my thinking...
-=Mike G.
2014 Rinker 260EC
x
Thanks! I'm learning every day!
EDIT:.. removed comment about signature.. posting new thread.
-=Mike G.
2014 Rinker 260EC
My Garmin GPS is set to "k t" instead of miles per hour... nuatical miles per our or knots. I'm an idiot. The boat runs great. I love it.
