There are LEDs that might 'fit' the connections, but they are typically too large in diameter. As RY noted, might be easier to replace with an LED light, I did with mine.
They are a little smaller, but I think they will cover the drill holes from the old fixtures. I was planing to pick 1 up this winter and see how far off it is.
I had found the LED bulbs for them at PepBoys a few years ago when I had lights like that on my old 232cc. Here is a replacement that is close in size. Link here.
On Ebay I found replacement LED bulbs for my 290. The EBay store is autosaver88. They sell in lots of 10 or 20. I have changed the cabin dome lights,cockpit, and nav lights.
I found the bulbs for the cockpit lights on ebay for $1. for 2 of them. also ordered the nav lights they were $6. for 4 of them. found cabin lights and the cabin dome lights same place for very cheap! Thanks for writing back everyone!!
I got all my lights replaced with led including running lights anchor ect.... With this company free shipping from China and good price just make sure that you know a little bit about lumen before ordering it could be a bit confusing http://stores.ebay.com/automotiveelectronicequipment?_trksid=p2047675.l2563
get a dremel and some epoxy, order the leds you want and make them fit into the housing you have, just be mindfull of the wattage. a 10 watt at 950 lumens is SUPER bright, actually proved to be too bright for my taste so I went back to the regular bulbs
There are companies that make the replacement LED bulbs, if you want to go that route. I found them at Pep Boys a few years ago. If you are looking to replace the entire fixture, then this one is close to what you might be looking for. http://www.replacementboatparts.com/LEDsurfacemountcourtesylight.aspx
http://www.westmarine.com/buy/west-marine--utility-light-led-oval-white--12645099
these were the nav. lights, they were actually more expensive than I remember, but they fit.
http://www.ebay.com/itm/271573705129?_trksid=p2060778.m2749.l2649&var=570399132270&ssPageName=STRK:MEBIDX:IT
these fit the above mentioned cockpit lights.
http://www.ebay.com/itm/220818185407?_trksid=p2060778.m2749.l2649&ssPageName=STRK:MEBIDX:IT
these fit the dome lights in the cabin.
