need a little input
1agofst
Member Posts: 16 ✭
i have 3.0 merc i/o
there is black smoke coming out of my exhaust and a black crud
we had it out for the first time this year and everything was fine and then the second trip was a no go,it was idling rough and blowing black stuff out of the exhaust,i cleaned the carb since the butterfly was not opening,it is now opening but still have rough idle and black smoke
could it just be bad gas or is it a carb problem
thanks
I had this issue with a Holly 4-bbl carb once. Had it rebuilt and everything was fine after that.
Check the flame arrestor for cleanliness, check any vacuum lines for cracks, replace the fuel filter/water separator, make sure your gas is fresh........the obvious stuff first. Someone else will probably have more/better advice.
Mark
2019 MTX20 Extreme
OP has a 3.0L Merc.....Alpha One. Good point though Boomer....what was the temp?
Mark
2019 MTX20 Extreme
Oil burns bluish to blackish.. super fuel rich does too, but more brackish than oil..
Pull a spark plug.. snap a pic of the business end.. post it.. let's get a look at what's happening in that thing!!
2019 MTX20 Extreme
Yikes.....18 volts??!? Can you take a voltage reading with a handheld volt meter? The helm gauges aren't the most accurate. If you still see that high of a voltage, I would suspect your voltage regulator/alternator. That would explain your hot battery.
Mark
2019 MTX20 Extreme
