Mercruise 5.0 non start
Tailsme
Member Posts: 20 ✭✭
I have a 2003 Rinker 312 with 2 Mercruiser 5.0 MPI engines. I have had an ongoing problem with the port engine for some time now, on occasions I will go to start the engine and it just cranks over but will not fire up, the engine will turn and expels air/fuel mixture from the air filer when I stop cranking, there is fuel to the engine, I have a spark and the fuel regulator pressure is correct. There seems to be a timing problem and I have tried changing the coil, crankshaft sensor and fuel regulator with the other engine to no positive results. The strangest thing about this is that I will try to start the engine again after some time (from 1 day to several weeks) and it will then fire up like there was never a problem. This has happened to me on at least 4 or 5 occasions since the summer and although it corrects itself over time there is a problem that I would like to resolve, I never know when this will happen and it does not seem to be consistent with hot, cold or damp weather. I am leaning towards the issue being electrical with a breakdown in a sensor or module that seems to correct itself at times. I have not been able to get a computer plugged into the engine while this problem exists and when the engine fires up again no faults are showing. I also wondered if this could be a distributor issue? It is a mystery to me and if anyone has any ideas on what this could be I would appreciate the input.
Thanks in advance for any help
Darren
good luck
Case in point: I too lost spark at the end of last season.. I pulled the boot off the coil and measured, and thought "well, that's good".. It still wouldn't start/run.. after a few minutes I checked spark again, but this time by pulling the boot off the dizzy tower.. one look explained it- it was straight up broken filliment.. swapped cables and it fired right up and didn't miss a beat.
The coil firing is one thing... The fire getting to the tower and then distributed out to cylinders is another.. even if you had one or two wires bad (from the dizzy) the other cylinders would fire, making a rough running engine, but coughing as in running all the same.. this kinda indicates a central problem...
A new dizzy cap and wireset is never a bad idea, anyway, for a winter project... I rec you swap em out, and pay close attention to the rotor button making sure it's seated properly.. word to wise: the last cap I bought was purchased with screws already in the cap, which weren't the right ones.. I pulled the screws out of the old cap and used them and went about my business... That is where your story points, my friend.
If there are good connections to the pcm and good grounds on that engine, it should at least cough of spark is even partially present. Check your grounds, and before investing money in wire sets, pull #7 wire and use it as your coil wire, leaving #7 vacant.. I bet it fires and runs rough..
A crack small enough to not be seen will allow moisture to collect on the points when a hot engine is turned off and slowly cools... A wet distributor flat out won't distribute spark... Until it's dry, or at least partially dry- when just a bit of spark is capable of flash frying a point dry, and then another, and another- and the seconds the engine catches life it's dry, and left a phantom to hunt, and never find... I can't tell you how lucky I was to figure that out, and the crack wasn't visible.. It took using it as a cup to see a drip on the outside.. The evidence? Strange deposits on the points...
Good luck, sir.
The plastic distributes heat fairly evenly unless there is a crack, or something touching it... With a crack, heat will focus there and make deteriorate even quicker... A decent cap is $15 or so... Don't cheap out!!!
LoL!
My daughter has her last day of high school in 3 days. I'm not looking forward to paying for that next cap either!
