Faria Gauge Replacement
Hamdog
Member Posts: 247 ✭✭
Hello Gang,
Well I'm pretty fed up with the Faria Gauges on my 2005 342. Even the tap method doesn't work anymore. The speedo, port trim, sync and both tachs are not working. What is the easiest way to replace my gauges? I'd rather not mess with the wiring so are there replacement gauges other than Faria that I can buy that basically just plug into my existing connections? What steps do I take to remove the old gauges?
Thanks.
Hamdog
Good luck and let us know how it goes. Mike
Sounds like a new Faria dash cluster if you don't have Merc MPI engines Hopefully replacement gauges come with the same connectors on the back as the originals.
I'm sure you're not alone. Don't bother with the Faria warrantee replacement program. Crazy expensive. Maybe Rinker has a recommendation.
Good luck.
Thanks
Late in the season I installed a Ray marine e7. So this winter i need to make a NMEA bus to get the 2 to talk to each other.
It's actually pretty easy. Once you get the main gauge in - the "System Gauge" the rest just plug and play. You daisy chain them together, on the back of each gauge, starting with the System Gauge is a data out port. You plug your next gauge into that, and that gauge will also have a data out port, which you can plug the next gauge into. Essentially it forms a bus communication back to the System Gauge which provides all the data each gauge needs digitally. So the real work is in getting the Smart Craft System Gauge in, the rest is a piece of cake. If you have a fairly new motor, the smart craft gauge will just plug into an available harness. Slightly older models will need an interface, which I believe Tiki put in - so he can provide the details.
All of my gauges still work like new (well except for the trim every once in awhile, when it has sat for a week or two it'll stick for a minute or two). I am going to add a Merc System Monitor (the SC1000, not the MercMonitor which is like $800). It'll give me fuel usage, codes, and most everything the higher $$$ monitors will, but its not able to be connected to GPS, so no instant MPG. Not too difficult to calculate by hand though with just a single screw.
Joe, your last sentence is not entirely correct. If you get the Speedo SC1000 gauge it does give you an estimate of MPG, based on the speedo reading. If you get the Tach SC1000 gauge, then you get the GPH.
I have the Tach gauge which has another great feature, you can set RPM between 500 - 800 RPM. This allows me to cruise at very low speeds, kind of like a speed control, which is great for trolling for fish. I can also slow my boat down a lot more than typical while docking.
I basically just take my MPH and divide by the GPH that the Tach System Gauge provides, and that gives me MPG. I know that at 30 MPH, I consume about 15 GPH, which is 2 MPG (basically my best fuel consumption point).
Serenity, Nice upgrade and an ingenious black starboard fix for those old oversized openings.
Mark certainly has that SmartCraft stuff ironed out. Gotta be happy with that realtime fuel consumption. It really makes the difference when trimming the boat at cruising speed.
My '04 270 got the LED Smartcraft multi gauge and proper Merc cabling. Easiest and most effect mod I added to the boat. It finally gave me reliable engine data. I called Merc customer support and got the right model numbers for the gauge and cable and then started searching. $150 for the gauge BNIB on ebay and $45 for the cable at a marine surplus store. 2hr install including cold beer consumption. Virtually plug-n-play. It was a perfect fit when I cut a hole in the dash right between the tach and Faria multi gauge.
Pressing the MOde button cycles between a nice large backlit display showing realtime temp/volt/trim/gph/fuel used/oil pres/raw water pump pres/blood pres/wifes disposition/# of beers remaining in cooler/stock quotes/etc/etc...
Generally an awesome device. Mike
