manifold, risors
rasburyrasbury Member Posts: 8,847 ✭✭✭✭✭
Not much discussion about this, I think I came up in two of the searches....the other was from someone else who had bought a low hour 2005 oddly enough. Anyway, with the hours low, trailered and fresh to brackish water and visual inspection determined good to go, I'm still wondering about mine. Can I pull out any of the plugs in the manifold/risors I see and get any sense of what the corrosion is inside?
Best Answers
    everything is running fine, recently had temp problems but that was my raw water pump and hopefully have that squared away....just don't want a few hundred dollars to end up being a few thousand dollars so will put pulling them on my list to do.....thanks all for the input.
