Battery switch on/off only
PauldanPauldan Member Posts: 24 ✭✭
I have dual batteries, switch does not matter what position it is in, everything always on.  anyone have this same problem?
    Hi
    look at those diagrams they should help you out  understanding how they work
    http://www.perko.com/images/catalog/pdf/Fig%208501-8504%20Inst%20%288500INS1%29.pdf
    Do you have a house battery switch?
    Here is a bette explanation
    The use of a switch and wiring like this is recommend with dual battery installations. A brief explanation of the operation of the switch in this circuit follows.
    In the OFF position, the two batteries are disconnected from all loads. The OFF position is used when the boat is being stored or otherwise not in use. It prevents any drain from the batteries. This can be useful if a circuit has been accidently left on, say a cabin lighting circuit or similar drain. Such a load can completely discharge a battery in a day or two, leading to an unanticipated dead battery situation when you return to your boat. On some switches a key lock is provided, allowing the switch to locked in the off position. The provides another level of security in preventing the boat from being used when left in storage or unattended.
    In the 1 position, all loads and charging currents are connected to the No. 1 battery (the PORT battery in the illustration). Starting current for the engine starter motor is supplied by the PORT battery. When the engine is running, surplus current developed by its charging circuit will flowing into the PORT battery. Current to lighting and other loads will flow from the PORT battery. The STDB battery is completely isolated and has no load current, nor does it receive any charging current.
    In the 2 position, all loads and charging currents are connected to the No. 2 battery (the STBD battery in the illustration). Now it supplies current required by starting and running, and it receives all the charging current from the engine. The PORT battery is totally isolated.
    In the BOTH position, the two batteries are connected in parallel. This has a number of implications. Unless the batteries have exactly the same state of charge, the combined voltage to the two batteries in parallel will sag to a voltage somewhat lower than the highest battery's terminal voltage. Current from the higher voltage battery will flow into the lower voltage battery and begin charging it. As long as the state of charge in one battery is higher than the other, the lower battery is more of a load than a source of power. Eventually, the batteries will reach an equilibrium, and they will both have the same terminal voltage. At that point they will both tend to supply current to loads that are attached to them, and they will both receive charging current furnished by the engine.
    It would seem like operating in the BOTH position would be beneficial, but that is not always the case. Even thought the batteries will eventually rise or fall to the same terminal voltage when connected together, they will not necessarily become exactly the same. A battery (or any source of electrical engery) can be though of as having an internal resistance. The lower this internal resistance the greater the current it can supply. The internal resistance will also affect how the battery absorbs charging current. Even though they are connected in parallel, it is possible that they will supply unequal currents to the loads, and it is also possible that they will accept unequal currents from an the engine charging source.
    If the batteries are significantly different in their age, their type of construction, and their state of charge, this unequal distribution of current can be more significant. To describe the situation in the simplest of terms, when two batteries are connected in parallel, they will probably tend to behave more like the weakest battery of the two than the strongest.
    Paralleling the batteries can come in handy in some situations. For example, both batteries may be discharged to a point where neither alone can provide enough current to crank the starter motor, but combined in parallel they can turn the engine over.
    If one battery is fully charged and the other is totally discharged, connecting them in parallel (by using the BOTH position) can cause very high currents to flow between the batteries. Extreme heat can be generated by the sudden charging of the discharged battery. Use caution in this situation. It is better to recondition a discharged battery by slowly re-charging it with an AC-operated battery charger.
    The arrangement of the contacts of the typical OFF-1-2-BOTH permits the operation of the switch in the range of 1-2-BOTH without ever disconnecting the batteries from the load or the outboard charging circuit. This is important, as it is possible to cause damage to the charging circuit if the battery is disconnected while the engine is running. By choosing the path of rotation of the switch, it is possible to change from 1 to 2 without moving through the OFF position.
  • PauldanPauldan Member Posts: 24 ✭✭
    Ok. thx for the input. Although I have two batteries , my switch
    ( stock part ) in the breaker panel is only on/off.  it does have a battery conditioner and charger but unsure if those are stock. Even when switch is in the off position , engine will start and electronics are on.  Also I have the mercathode device so will need to disable this in drydock.
    Thanks for this video. make more sense now. I only need the switch with one position because I do have the dual bank on-board batter charger - ProMaster12.
    Just have to figure out if both batteries will drain at the same time or one is always isolated form running electronics.
    Cheers!
  • My_Dinghys_DinghyMy_Dinghys_Dinghy Member Posts: 107 ✭✭
    Pauldan, How do you like that ProMaster12? I am looking at purchase that model.Pauldan said:
    Doing a 25 year old Project Boat after a 35 year hiatus from boat ownership.
    Catch us on Kelley's Island at the Seaway or Portside Marina or Middle Bass at the State Park Marina MOST SUNDAYS and weekends in July! Call My Dinghy on Channel 16.
    If youre worried about discharging one battery (ie radio on a long time and lights on) and not being able to start the engine with out moving the switch from position 1 to position 2, you could just run a BIG wire from battery 1 to run your lights and radio. And keep the battery switch on number 2.
    With the isolator in place this arrangment will keep both batteries separate and all the electronics (radio etc) will run off of battery 1 and the start will come from battery 2. When you run down the bat 1 just start the engine and it will charge
    Hello My_Dingy -  the Pro master seems to be great. it keeps both batteries nicely charged and so far have had no starting issues. Also the batteries are 2007!  I will replace these however before summer.
    Guys I'm trying to figure out plain and simple if I should keep it on 1 or 2 for my 2006 270.  I am still learning how all this works being a new boat owner.  Also, is there a tell tale sign for making sure my house and crank battery are in the right position.  Making sure I don't have them backwards...I was told to following wire from start to crank battery is a good way.  Appreciate it.
    Patrick
    06 Rinker 270
  • usafaviatorusafaviator Member Posts: 41 ✭✭
    Pauldan, i also have a 230 EC, i just added a second battery and im about to mount my deep blue sea switch soon, would you mind snapping a picture of where your switch is located on the breaker panel?  I want it as close to stock as possible. Thanks
    2007 230 ECC 350 Mag MPI Alpha 1
    I will take a Pic and post. The battery switch I checked is a odd config. 0 or 1 . the 0 position is using the main starting battery to start the engine. the 1position links both batteries together for starting and is also the position needed to charge the house battery.
    I have now installed a battery isolation block, this switch in picture is now used for emergency start - both batteries in parallel.
