do these numbers sound right?
Hey all I have a 1995 265, (454 carb 22p stainless prop) and am now learning to drive it. Last year I spent most of the time in the slip fixing things. Now that everything is working as it should (except trim tabs) Im driving it more. I have found that I can stay on plane down to 23mph (gps) at 3100 rpm. and at 4500 rpm Im hitting 37 mph. Are these speeds acceptable for the 265?
Thanks
Steve
Thanks
Steve
the gear ratio is printed on the drive, if it still exists... it may be stamped into the casing.. 10% slip is accpetable, whereas 5-7% is perfect.. you want some slip, just not that much and consistent.
now if you're running 1.61:1 @ 7% slip? good times,
Thanks for any and all info
http://www.go-fast.com/Prop_Slip_Calculator.htm
You're most likely pushing 2:1 gear ratio with that big block... If so, you're slipping 20%, which can be fixed by either having that stainless prop worked, or, buying a new one..
What is your top engine speed? 4500 is at bottom of good.. I'd like to see you hit 4800, instead. But, if the 22p is only letting you see 4500, its about right if not a little over propped... All things remaining consistent with prop geometry, a 21 will put you at 4700, and likely not drop your speed much at all.
I'd like to hear what prop you're running, too.. blade geometry makes all the difference in the world. if its not a progressive pitch, or if it is too progressive, that could be why you're slipping so much. Three blade? Four? and.. we'll know more about what to tell you with all that info. .
Thanks
Steve
